Help needed please !
Discussion in 'AV Receivers & Amplifiers' started by John G, May 27, 2001.
  1. John G
    John G
    Nov 25, 2000
    308
    Matlock, Derbyshire
    +54
    I have just bought a Denon AVR 3801 and have been hooking it up today.I know someone is going to call me dumb but I cannot seem to access the on-screen set up menu.I have checked all conections but have an idea I am missing somethind really basic.Any help much appreciated.Thanks,John
  2. pauld
    pauld
    You must connect the s-video connection to your tv from the video out connection at the rear of the amp. I dont have it permantly connected, I just connect it when I need to acces the menu which is very rare once set up.
    Hope this helps
  3. Arthur.S
    Arthur.S
    What Paul means, is that you've probably got the pic from your player going direct to the TV. You need to connect to DVD-in on your amp, then either DVD/monitor-out to your TV. If the pic doesn't go through your amp, you won't be able to see it.
    If that's not the case, maybe there's a 'display' button somewhere on the remote?
  4. John G
    John G
    Nov 25, 2000
    308
    Matlock, Derbyshire
    +54
    Thanks for your replies guys.I have connected an S-video lead from Monitor S-video OUT (on the back of the Amp) to S-video IN on the front of my Sony TV as it says to do in the manual but I still cannot access the the Set-up menu.Does anyone have any oyher ideas? Thanks again,John
  5. Gary Palmer
    Gary Palmer
    Jul 17, 2000
    333
    16
    John G,
    Don't want to ask the obvious but when you select different video inputs on the amp do you get the required picture on the telly ?
    Are you connected to the TV directly from the DVD player (RGB Scart) as well as s-video from the amp ? If so you may need to force the TV to use the correct video input (it may default to RGB if there is a signal)
  6. pavlos
    pavlos
    Mar 5, 2001
    11
    I have the same setting and it works fine, did you remember to change the AV3 option from the sony TV settings from rear to front?
    pavlos
    [ 28-05-2001: Message edited by: pavlos ]
