help needed please
Discussion in 'Cables & Switches' started by gooner2, Dec 31, 2004.
  1. gooner2
    gooner2
    Jan 5, 2002
    27
    I am asking this on behalf of my elderly father in law, his problem is this, he has a JVC tv, and a Strong sat reciever, a Thompson freeview box and the most recent a Bush combined VCR and DVD recorder, could anyone tell me how these 4 items should be connected, for one thing he cant record anything from his freeview box onto the Bush recorder so something is not right, all four items have 2 scart sockets which I think is what he has connected them with, I hope this is the right forum and I hope someone can help me in simple english, thanks in advance.
    Colin
    Happy new year to all
  2. CfP
    CfP
    Gooner2,
    bit of a tricky question that one....... There are several approaches:
    1. Route all transmissions (Sat, Freeview) through the DVD-R/VCR and then have that signal go out to the TV (so the VCR/DVD controls all TV selection and the TV is effectively just a display).
    2. Plug EVERYTHING (Sat (in), Freeview (in), VCR/DVD-R (in/out)) into the TV direct and hope that the TV has a line out for vid and audio so that the VCR/DVD-R can record from it.
    Option 1 will give the best recorded picture (as there's nothing between the in signal and the recorder) but is at the trade-off of possibly not the best displayed picture (all signals MUST go thru the video which may reduce the quality).
    Option 2 will give the best displayed picture (on TV) but may not give the best recorded picture (DVD-R in reality. VCR can't store the info anyway ;]). Added bonus here is that you don't need to turn on the video to just watch a bit of telly.
    Good luck, bounce some more info if need more help. :smashin:
    CfP
  3. gooner2
    gooner2
    Jan 5, 2002
    27
    CfP many thanks for your reply, not sure I understand but will print your words off and take to inlaws house and see what I can do.
    many thanks again.
  4. CfP
    CfP
    Will see if I can knock up a basic diagram for you and post it up :thumbsup: As always, a picture tells 1000 words (geeze, almost as long as my posts :laugh: )
    CfP
  5. gooner2
    gooner2
    Jan 5, 2002
    27
    Thanks again my friend, that would be a great help.
  6. CfP
    CfP
    :clap:
    How's this look then ;)
    [​IMG]
    Only prob is you may not have enuf inputs on the TV (Opt 1) or Vid (Opt 2). Should keep yo busy ;)
    Alternatively, you may be able to use some sort of SCART switcher to route things into the TV (Opt 1) or into the VCR (Opt 2).
    CfP
