help needed philips 32pw6615/25
Discussion in 'General TV Discussions Forum' started by mannafig, Jul 13, 2005.
  1. mannafig
    mannafig
    May 19, 2005
    967
    lowestoft
    +12
    Can some one tell me what buttons i have to press to get to the setup menu. Also anyone know where i can get the owners manual from.Got this tv 2nd hand no owners manual and not sure i have the right remote.Any help much appreciated
  2. JayCee
    JayCee
    Jan 20, 2004
    22,327
    Lanarkshire
    +2,327
    The owners manual can be downloaded from here :smashin:
  3. mannafig
    mannafig
    May 19, 2005
    967
    lowestoft
    +12
    thank you for that now just need to find actual remote number so i can set this up .my remote looks nothing like the pic in the manual :( . any one know what buttons to press to get into initial setup all i know is that its 2 buttons simultaneously.
  4. JayCee
    JayCee
    Jan 20, 2004
    22,327
    Lanarkshire
    +2,327
    Yes, it's a "diamond" and half-diamond" usually under a hinged flap and connected together with a line
    Hope this helps.
  5. mannafig
    mannafig
    May 19, 2005
    967
    lowestoft
    +12
    thanks again for that :thumbsup: going to have to buy a new remote mine is the wrong one all my remote does is turn on the tv,adjust the volume and change channels :(
    thanks again for your help JayCee :smashin:
