Help needed ordering LOTR.
Discussion in 'Movie Forum' started by dAvE6, Aug 5, 2002.
  1. dAvE6
    dAvE6
    All my dvd's(about 5) whether they are region 1 or 2 have always had black borders on my widescreen TV. A bit ironic considering that's what they are designed to prevent. So prefferably i want lord of the rings to fill the whole screen.
    Do i go for the widescreen R1 version or the fullscreen R1 version? I'm definetly going for region 1, but just don't know which. Remember that it's a widescreen tv that i have.
    Thanks very much.
  2. Tafsir
    Tafsir
    Jul 9, 2002
    1,230
    63
    uk
    +99
    it could be something to do with the setting on the dvd player m8
    i think you get 3 setting types
    4:3
    16:9
    letterbox
    toggle between the formats
    Tafsir
  3. nwgarratt
    nwgarratt
    May 5, 2002
    27,152
    +3,022
    if you have got a widescreen TV the you want the widescreen version.
    You will still get the black borders, but not as much as a 4:3 TV as it is in 2.35:1 ratio.
  4. DaveP
    DaveP
    Your problem is that your films are in 2.35:1 aspect ratio. If you buy the full screen version you will still get black lines, but this time they will be down the sides!
    There seems to be a big disagreement whether or not 2.35:1 is a good thing or not. In my case it's the ratio of choice! Others cannot abide it.
    What you want is a 16:9 ratio. This is usually shown as 1.85:1 on the box. I'm not sure if you can get LOTR in this format. It may be worth looking at Region 4 suppliers.
    Sometimes you'll get both 4:3 and 16:9 on the disks.
    My personal opinion is that if you don't like the black bars at the top and the bottom of the screen you are better off buying 4:3 disks and having them at the side.
    In either case you can always stretch them! Not quite what the director had in mind but then again he didn't have a 4:3 picture in mind either!
    DaveP
  5. dAvE6
    dAvE6
    What i'm really asking i suppose is whether the R1 fullscreen version will give a full-screen image on a widescreen tv??
  6. billduff
    billduff
    Mar 17, 2002
    275
    16
    Just to the right of civilisation
    Do NOT get the Full Screen version. If you have a WS TV never get a full screen version (IMHO they shouldn't even be on sale !!!)
    The black bars you are getting are propbably to do with the ration the film is filmed in. I am not an expert in this but here is good link to explain WideScreen Explained .
    Basically TV's are 16:9 format bit films are often 'wider' than this. So to get the full width on screen they lose some height, that explains the bars at the top and bottom of a WideScreen image.
    The doclink above explains it in a lot more detail and tells you about the difference formats etc.
    Also follow tafsir's advice and check all your DVD and TV settings again.
  7. dAvE6
    dAvE6
    Ah thanks, i guess i'll buy the widescreen version. Thanks for explaining it all.
