HELP NEEDED: optimum stand max load?????
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by Twan1, Jan 2, 2005.
  1. Twan1
    Twan1
    Dec 19, 2004
    1,132
    38
    Essex
    +22
    hiya all,
    I have a 5 tier optimum av stand which holds everything i need for my av no problem, 4 of the shelves are 5mm glass, top shelve is toughened 10mm glass to support my 42" Plasma.
    I am planning to buy a 50" pio plasma which is 42KG in weight, will the 10mm glass support this???
    Thanks all
  2. bobbypunk
    bobbypunk
    The 10mm glass on the AV(x)00 models are fine with the 60kg of the hitachi 55"
