help needed on which wall mount to buy for pw6?
Discussion in 'Home Cinema Buying & Building' started by 2naughty4u, Mar 24, 2005.
  1. 2naughty4u
    2naughty4u
    Mar 22, 2005
    26
    London
    Hey guys
    I just bought a panasonic th42pw6 and I was wondering if anyone could give me some advice on a reliable,strong and safe wall mount (I will be mounting the plasma on a solid brick wall)
    I was looking for just a simple flat wall type mount (but I dont mind a titling one as long as its about 20-30mm from the wall) and I found these:
    video services, veda debut for pany £120
    av sales slim tilting mount for £109
    rs100 ultraslim mount for £79
    can anyone recommend the best one or if youve got any suggestion. I would be very grateful
    :thumbsup:
    ps would I need to require any depth bars for my plasma?
  2. Tarsh
    Tarsh
    Jan 9, 2005
    52
    9
    Essex
    I used the AV-Sales mount with my Panny 42PH7, it was very easy to install. :)
    No experience with any others, though.
  3. Supersonic72
    Supersonic72
    Jan 10, 2005
    244
    Can recommend the AV sales mount which I stuck up on the wall on Saturday
    Me and my old man located it on the wall with a 18mm sheet of MDF to create
    a solid sandwich to the wall, so the plasterboard didnt shear all the weight by
    itself, and got me some 90mm long window fixing screws/plugs to sink into
    the wall. B & Q have them, theyre in the red bags for heavy duty weights.
    I got the 8mm head bolts, and would have gone for the 12mm ones but they
    were longer too at 110mm, but I didnt have a long enough or wide enough bit
    for my drill. Otherwise, they would have been a nice deep fit.
  4. 2naughty4u
    2naughty4u
    Mar 22, 2005
    26
    London
    Thanks for the reply guys
    I was also wondering how slim is the wall mount from avsales?
    and is the panasonic rs100 flat wall mount as good as the veda debut?
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
  6. 2naughty4u
    2naughty4u
    Mar 22, 2005
    26
    London
    thanks for that HD
    would I need spacers for my pw6?
    by the way what wall mount do you have for your plasma?
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    you will need spacers (large nuts work but proper spacers better), and who said i had a plasma???
  8. Alexg
    Alexg
    Aug 7, 2001
    234
    16
    What are the spacers for? do they sit behind the mount to space it from the wall?
  9. Alexg
    Alexg
    Aug 7, 2001
    234
    16
    Also, what are the "space bars" for?
  10. GiZZeRR
    GiZZeRR
    May 24, 2003
    Edinburgh
    I just put up mine with the RS brackets and it was a doddle to do. Yes no spacers but I didn't use any anyway. I just used the longer bolts and tightened them a little tighter than finger tight. No way are they going to work loose while it is hung on the wall. If your worried about that hapening then just use some loctite on the threads but I would not worry about it.
  11. mooic
    mooic
    Mar 24, 2005
    3
    Widnes, Cheshire
    Hello all, this ios my first post so go easy on me :)
    The spacers are used to space the bracket from tha back of the panel because the bolt holes are recessed, if you dont use ny you could damage the back of the panel!!! (over 200 wall mounts and still going!!!!)
  12. GiZZeRR
    GiZZeRR
    May 24, 2003
    Edinburgh
    Yes as far as I can see if you keep tightning up on the bolts it will pull the back of the panel casing in.....as I said if you use the longer bolts, tighten finger tight and then a little bit more you should not have a problem. If you're worried then use some sort of spacer....mines is up now and is perfect and there is no way the bolts will unscrew themselfs.
  13. 2naughty4u
    2naughty4u
    Mar 22, 2005
    26
    London
    Thanks for the reply back geezer
    what are the bars like that fit on the back of the plasma. are they quite slim & strong? and can you lock the plasma in place once youve mounted it?
    and can you get spacers from B&Q? or do they have to be specially order or something
    sorry bout the silly questions but I really new to all of this :confused:
  14. normies
    normies
    Hi - first time poster!
    I have a PW6 and I have seen OMNIMOUNT brackets, they look very strong, but are expensive, anyone know about um?
  15. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
