help needed on dvi output nvidia
Discussion in 'Desktop & Laptop Computers Forum' started by hammy2891, Nov 10, 2004.
  1. hammy2891
    hammy2891
    how do i enable the dvi (digital) output to my pj on my nvidia geforce fx5200 ?
    it was working then i pressed the "analogue display" button and cant get it back,i have uninstalled the driver and re-installed but to no avail,there doesnt seem to be any settings in the properties for the dvi output,is this right?
    any help would be appreciated.as i am stumped and pulling out what little hair i got left.
    :lease:
  2. hammy2891
    hammy2891
    :lease:
    come on peeps help me out here missing valuable veiwing time
    :lease:
  3. Kramer
    Kramer
    Unplug any other connected devices, VGA monitor/s-video (TV etc.) & boot up with PJ switched on. It should automatically detect the PJ & send it a signal/picture, via DVI.
    You should then, hopefully, be able to sort out any problems.
    :smoke:
  4. hammy2891
    hammy2891
    kramer
    thanx for advice,got a picture back on pj but only as a clone when i go into dualveiw to give it its own resolution i loose it agaain & have to disconnect vga to monitor and re-boot.
    Does any one no if i can run dvi 2 pj at a different res' than the vga 2 monitor (monitor does not support 1280x720)
  5. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    From my brief play with an FX5700 before going back to my ATI, I seem to remember it was possible to set up different resolutions, but I can't recall how.
