Help needed on Cinemax
Discussion in 'Projectors, Screens & Video Processors' started by wexx, Mar 1, 2005.
  1. wexx
    wexx
    Hi, I just bought a used Cinemax and as I know it does not have LIMO or colour corrected lenses. I already have a Cine 7 and plan to marry the Cinemax to a Faroudja 1010. Do I still need the LIMO ? Can I use the one on the Cine7? Also, what about the colour correction ? Should I have it and if so, how can I do this?
    With thanks,
    Alexander
    PS I still resist the DLP armada. Instead of rainbow effect you get splitting headaches now (At least I do) :)
  2. crteaman
    crteaman
    May 18, 2004
    428
    +6
    Hi Wexx,
    No limo and no colour filtering are you sure??????
    james (crt)
  3. Gordon @ Convergent AV
    Jul 13, 2000
    14,245
    +3,111
  4. crteaman
    crteaman
    May 18, 2004
    428
    +6
    As gordon said,is it a 909, cine 9's could be ordered without limo pro at a reduced cost,but no clour filters,are oyu sure?? being a max I take it the case is the silver one.
    james (crt)
