Help needed making 5.1 trailer compilation
Discussion in 'Desktop & Laptop Computers Forum' started by maxiboy, May 12, 2005.
  1. maxiboy
    maxiboy
    My problem is this:
    I want to make a compilation dvd of trailers- easy you might say, but I am looking to mix formats from different sources and maintain 5.1 sound when present. I am also looking to make all aspect ratios work on my 16:9 projector (so for example a 4:3 trailer is seen as a 16:9 aspect with black pillars either side).
    Due to the fact that it will be seen on a 6 foot screen I want the quality of the source material to be maintained.
    I have tried using nero vision express and have not got 5.1 sound to work alongside 2.0 ect
    I have tried ulead dvd workshop, can get aspect ratio sorted but having real trouble with sound.
    Is there a straightforward way to do this, obviously it is by no means a matter of life and death but you know when you get an idea in your head.....
    Any help would be greatly appreciated
    Max
