Help needed!, issue with my Marquee 8500
Discussion in 'Projectors, Screens & Video Processors' started by gorgebug, May 18, 2005.
  1. gorgebug
    gorgebug
    Apr 19, 2004
    108
    Bournemouth
    Here is my problem: after switching it on and watching sky+ or dvd for no fixed period of time the picture disappears (goes black) then I can hear a click from the pj & then approx 5 seconds later the image comes back on as multiple thin red, green and blue horizontal lines (which sometimes zig-zag from top left to bottom right)
    I then switch the pj off and switch it back on and to start with (first 10 times this happened) the normal viewing image returned, now only the lines return
    I will take a digi picture and post it, if anyone thinks this will help
    Any ideas? :lease:
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    I would point the finger at the input board. does it do it via any other sorce ie video fed in with no scaller etc.
  3. gorgebug
    gorgebug
    Apr 19, 2004
    108
    Bournemouth
    Thanks for your reply Roland
    I will try and feed a dvd through a laptop straight to the pj and see if the fault still exists
  4. koentav
    koentav
    May 26, 2005
    4
    Cheshire
    Hi Gorgebug,
    This sounds exactly like my problem:
    http://www.avforums.com/forums/showthread.php?t=215515
    just that my projector is a barco and the diagonal lines go from the right hand top to left hand bottom. Is the image a lot brighter too?
    If you get your problem solved I'd like to know how! :)
    Good luck with it.
    Koen.
