help needed in mounting a pj to a 45 degree ceiling
Discussion in 'Home Cinema Building DIY' started by Kax, Jul 25, 2005.
  1. Kax
    Kax
    Hi everyone,
    I'm not sure if this is the right place for it, but I'm getting my Marantz VP-12S4 by the end of the week and I still haven't found a good solution for mounting it on my ceiling.
    I want to "hang" it from a beam, which is at a 45 degree angle relative to the floor, at about 1.3 m. straight below that beam. The pj weighs about 13 kg's.
    Does anyone know of any (ready-made) solution with which I can safely mount this pj to that beam? Most solutions I found so far, are either too short, or can't be angled far enough.
    Any help would be appreciated.
    TIA,
    Kax
  2. theendisnye
    theendisnye
    Oct 11, 2004
    64
    Have you thought of making a wedge so that you can then use a standard support, effectively ending up with the 'ceiling' back at 90 degrees or thereabouts?
    Steve
  3. Kax
    Kax
    Thanks Steve for your reply.
    Yes I have thought about making a wedge, but the problem is that the wedge will have to be attached to the beam and the pj to the wedge. Since this will result in 6 to 8 holes in the wedge (standard supports usually are attached with 4 screws/bolts), I wouldn't feel comfortable using wood, because I'm afraid that (especially on the thin end of the wedge) the wood will split.
    A metal wedge would be the answer, but I don't have a welder.
    That's why I'm hoping someone knows of some ready-made solution, or perhaps another solution I haven't thought about yet.
    Thanks anyway for thinking with me,
    Kax
  4. dotcomslashnet
    dotcomslashnet
    Jul 25, 2005
  5. klr10
    klr10
    Dec 20, 2003
    801
    28
    Sawbridgeworth
    +27
    www.unicol.co.uk - they will help if you can't find a suitable bracket from their range.
    Hope this helps, Keith
  6. Kax
    Kax
    Thanks Keith,
    Their tilting ceiling plate looks just the ticket. Only problem is that the columns that go with it are either too short or too long, and it doesn't look like they can simply be cut to the right lenght. I'm going to try to find out if it's possible to order a custom length.
    Meanwhile, everybody: keep the good ideas coming.
    Thanks again,
    Kax
