help needed!!!! I have a 37lg5000
Discussion in 'LG TVs Forum' started by rchads89, Feb 2, 2009.
  1. rchads89
    rchads89
    Nov 30, 2008
    4,774
    +269
    I have a lg37lg5000 i have hdmi 1080p max res to ps3... i am after some display settings for the ps3 as they are so different to what xbox 360 uses. what settings should i be using with this tv and the ps3 because atm i have just got everything on max and i don't want to cause the tv or the ps3 any damage.
    please help cheers
  2. J4CK DANIELS
    J4CK DANIELS
    Aug 3, 2006
    1,483
    +231
    Don't worry about 'damage' the screen will accept any of your PS3's resolution settings. ideally it needs to be set to 1920x1080 (1080p/Full HD etc..)
  3. rchads89
    rchads89
    Nov 30, 2008
    4,774
    +269
    Yeah i have got it on 1080p max res, but i was on about the colour reduction on/off that white something settings :s on/off . RGB setting limited or full ??
  4. J4CK DANIELS
    J4CK DANIELS
    Aug 3, 2006
    1,483
    +231
    Sorry i can't be of any more help, I've got a 360, don't have a PS3.... there's not really a right or wrong though... whatever looks best/works!
  5. rchads89
    rchads89
    Nov 30, 2008
    4,774
    +269
    Oh right ok so whatever i set it too it won't like damage the tv or the ps3 or anything along them lines?
  6. J4CK DANIELS
    J4CK DANIELS
    Aug 3, 2006
    1,483
    +231
    nooooooooooo, it'll be fine I promise! if the TV doesn't like something (signal) you give it it will simply say 'OUT OF RANGE' or 'NO SIGNAL' but it won't cause any damage at all.
  7. rchads89
    rchads89
    Nov 30, 2008
    4,774
    +269
    ok thanks mate, i will just bang everything up on full sure the lg can handle it.
