Help needed! Hisense M3000 Screen goes black after a second of switching on
jimmybob101
I have an issue with my Hisense M3000 50 inch television. I still have sound coming from the television however the screen is black. When i go to switch the television on it lights up the Hisense Logo for a second and then the screen goes black with the sound still working.
I would appreciate your help.
JayCee
You've got a fault, it's known as no backlight.
Have you tried a mains power reboot...other than that you'd need it looked at by a professional.
How old is it?
jimmybob101
It is only two years old. I have removed the power to the mains overnight however it still loads the backlight with the Hisense logo being visible for around 1 second and then goes black. Doing abit of research it appears that it could be the T Con board?
JayCee
Complain to the place you bought it from.
You have rights under UK Consumer law.
The T-Con board isn't likely to be the cause of your symptoms.
