For some reason networking is a mysterious black art to me, it totally bamboozles me.
I have been trying to set up media streaming in order to stream divx and avi files to me TV. I used to achieve this by file transfering the files through FlashFXP and a crossover cable, however as I my HDD has not been upgraded I was always limited in drive space and could fit a max of 3 files.
How do I go about setting up my xbox and pc to stream media, hardwired to my desktop machine using the ethernet cable that comes with the X360?
To date, I have sussed out that I have to use a little crossover convertor box for the PC to recognise a connection has been made. I assume this is because a crossover network cable and not an ethernet cable should be used?
So I have the little balloon popping up at the bottom right showing a 100mbps connection. I then set up my HDD containg my media on the PC as a shared drive using this guide. http://www.xboxmediacenter.com/wiki/index.php?title=Windows_File_Sharing_(samba/smb)
Now I have in my list of drives on XBMC an option for (SMB)Network? I selected this, the machine freezes for quite a while, then I get an image of a keyboard on the screen and it asks for my network name and then after that password?
What do I do at this point and am I on the right track with this?
I really want to get this working, when I do/if I do, will it all work with the Xbox media remote?
Sorry if the above makes no sense, I will clarify any part of it thats confusing.
