Help needed for Panasonic recorder
Lesleyann
panasonic DVD recorder DMR-XS350EB will not record a series of programes, used to ok, but all it does flash the red light when the time is ready but does not record, any ideas !!
Gavtech
Administrator
Welcome to the forum
I have moved this post from where you first put it.
Check that you have the latest software.
This was a problem of early software versions.
You will probably find the current software version you are running in : Functions / To others / Setup / Others/ System Update
V1.5 can be downloaded from here
