B
Budgie
I've been trying to edit some video on my PC, using several (trial versions of) DV editing software including Premiere as well as MS MovieMaker (part of XP).
During capture, I keep dropping frames ... any ideas why.. what order of tests should I go through to identify the problem?
I've tried 2 MiniDV cams... still the same
PC is P4 2GHz /WinXP/ 256MB RAM / 60G HDD (probably needs to be bigger, but could a HDD problem cause capture problems?)
Firewire connection
Any help gratefully received!
Ta
Thanks Fats for pointing out that I hadn't put the proc. speed... its 2GHz as you can now see.
Firewire connection
Ta
