Help Needed DMR ES10 DVD recorder connected to a th42pe50
Discussion in 'Plasma TVs Forum' started by RHCP, Oct 26, 2005.
  1. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    Haven't needed to connect my free DMR ES10 DVD recorder to my plasma until now. (i've had it for a month, lazy i know but i've already got a decent dvd player). My dad has just rang and asked me to record him a program on bbc4 tonight at 1:40
    Reading my plasma manual it says i can connect my dvd recorder the tv's scart 1 or 3, which are Qlink, reading my dvd recorder manual it says 2 & 4 are Qlink :eek: ! :eek:
    My Plasma manual also shows that i don't need to plug my ariel into my dvd recorder because it will download all the programs from the screen.
    This just doesn't work! :confused:
    am I mad?
    Can i record from digital channels or only the 5 regular ones?
    Am i Mad ? ? ?
  2. bobboulby
    bobboulby
    Sep 22, 2005
    99
    West Yorkshire
    1. Connect the DMR ES10 to AV3 on the TV - there is no need to connect the aerial.
    2. In the TV Setup menu, set Q-Link to AV3.
    3. Set a timer event on the TV for the program you wish to record.
    4. When the program starts, the TV will wake the ES10 and it will start recording.
    5. When the program finishes, the TV will instruct the ES10 to stop.
    Simple :thumbsup:
    Bob
  3. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    Cheers i'll try that now.
  4. Majid Khan
    Majid Khan
    RHCP , i'm wondering how would you go about recording from the integrated Freeview channels on your plasma?
    Eg, If you hook up your dvd recorder to your plasma via scart, would this enable you to tune in all the Freeview channels onto your DVD recorder?
  5. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    what do i set the "AV3 out" to?
    Where is the timer event?
    Can i record bbc4?
    Cheers :)
  6. bobboulby
    bobboulby
    Sep 22, 2005
    99
    West Yorkshire
    If you connect everything up in the way I have described, you can do exactly that.
    Bob
  7. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    Hi Majid,
    Dunno what i'm doind just yet!
    I'll let you know when i'm sorted!
    Where's bob!
  8. bobboulby
    bobboulby
    Sep 22, 2005
    99
    West Yorkshire
    Set AV3 Out to 'DVB'.
    You can set a timer event by pressing 'ok' on the program in the guide. See p32 in the manual.
    Yes you can record any Freeview channel.
    I suggest you do a test before your 'real' recording.
    Bob
  9. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    my av3 is just a blank white screen, is this right?
  10. bobboulby
    bobboulby
    Sep 22, 2005
    99
    West Yorkshire
    If you've connected AV3 to the ES10 then the screen will be blank unless the ES10 is switched on. If the ES10 is switched on then you should see output from it.
    Bob
  11. bobboulby
    bobboulby
    Sep 22, 2005
    99
    West Yorkshire
    Try this test before you do a timed recording. With the ES10 in standby, press the 'Direct TV Rec' button on the TV remote. This should wake the ES10 and start recording whatever is on the TV.
    Bob
  12. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    Something is not right here!
    My av3 is blank white, i can move the channel up and down, but all that appears is in the corner "No Disc" "BBC 1" "mono" "L R", then bbc2 itv1 and so on!
  13. bobboulby
    bobboulby
    Sep 22, 2005
    99
    West Yorkshire
    I think your ES10 must be using its own internal tuner and not seeing the TV tuner. Give me a minute while I check the manual.
    Bob
  14. bobboulby
    bobboulby
    Sep 22, 2005
    99
    West Yorkshire
    Is your SCART connected to AV1 on the ES10? If so what happens if you press 'Direct TV Rec' on the TV remote?
    Bob
  15. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    I've just set the dvd to record at 10pm on itv2, i'll let you know if it works in a minute!
  16. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    Didn't work!
    direct record works, but i don't know what its recording, it says A1 on the dvd recorder!
  17. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    Yeah, I'm connected to Av1 on the dvd!
  18. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    The screen now says dvb tuner locked!
    Should i stop the recording and see what its done?
  19. bobboulby
    bobboulby
    Sep 22, 2005
    99
    West Yorkshire
    Did it record on the DVD - can you play it back?
  20. bobboulby
    bobboulby
    Sep 22, 2005
    99
    West Yorkshire
    Yes.
    Bob
  21. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    Yes its recorded the history channel, the channel that i was on.
  22. bobboulby
    bobboulby
    Sep 22, 2005
    99
    West Yorkshire
    If it hasn't worked try this test.
    Set the ES10 to standby.
    Press 'Direct TV Rec' on the TV.
    Does this wake the ES10 and start it recording?
    Bob
  23. bobboulby
    bobboulby
    Sep 22, 2005
    99
    West Yorkshire
    Ok - good, so a timer recording should work as well.
    Try another test - you can manually set a timer recording through the DVB Setup menu.
    Bob
  24. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    Yeah, but just a black screen now with AV3/RGB in the corner, the dvd recorder is showing av2 now, but it is recording!
    Sorry this was the answer to your other question, i'll try that one now!
  25. bobboulby
    bobboulby
    Sep 22, 2005
    99
    West Yorkshire
    If the timer test works, you should be ok. Just set a timer for the program you want to record, put the ES10 into standby and the TV into standby when you go to bed (don't switch it off).
    If not, sorry but I'm running out of ideas - it's difficult when you can't see what's going on.
    Bob
  26. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    Right!
    Now getting a picture through av3, with the dvd showing A1 on the front.
    I can't change the channel up and down from the dvd, is this because the ariel is going through the tv?
    When i change the channel on the dvb on the tv, then go to AV3 i get that channel, is this right?
    I think were getting somewhere :rolleyes:
  27. bobboulby
    bobboulby
    Sep 22, 2005
    99
    West Yorkshire
    That's right. You won't be able to change the channel on the DVD, just on the TV. This is because you are using the TV digital tuner to feed the DVD recorder. The DVD recorder only has an analogue tuner (channels 1-5).
    Bob
  28. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    Works! Phew ! :thumbsup:
    Beer for bob !:beer:
    Cheers mate! :)
  29. bobboulby
    bobboulby
    Sep 22, 2005
    99
    West Yorkshire
    You're welcome mate - I'll collect it next time I'm in Liverpool :D
    Bob
