Help needed: copying on Sony RDR-HX510 HDD/DVD recorder
Discussion in 'Blu-ray & DVD Players & Recorders' started by spierian, Jul 23, 2005.
  1. spierian
    spierian
    Can I copy from the hard disc to a DVD on this machine?
    I am archiving some old video tapes and I want to edit them before finally comitting to DVD-R.
    My plan was to record to HD, edit there and then copy to DVD-R
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    Yes. All the major HDD/DVDR combis will allow this - note that the editing on some machines is better than others - but the Sony does a decent enough job.
  3. spierian
    spierian
    The problem is that I cannot find how to copy from HD to DVD.
    Where is the command located?
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    If you look at p72 of the user manual it gives you a full description of the various ways you can dub.
  5. spierian
    spierian
    You are a star. I never thought of the word "dub" as meaning "copy".
    Thanks a lot. This solves my problem.
    John
