HELP NEEDED: Connecting a Home Cinema to my Arcam
Discussion in 'Arcam Owners' Forum' started by rigger, Aug 29, 2004.
Tags:
  1. rigger
    rigger
    I have a Sony VPL HS20 Home cinema and I want to be able to connect it so that I can get my TV and video through the system as well. My amplifier is an ARCAM ALPHA AV50. The cable that came with the projector has your Yellow S-Video, Green, Blue, Red and a 5 pin connector. The shop has said that this cable will be able to connect everything.
    :lease:
  2. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    From memory the AV50 supports only composite video (probably the single yellow phono socket on your PJ). Good quality sources like a DVD player or set top box should therefore be connected direct to the PJ via s-video or component for best quality video.
    HTH.
    John Dawson (Arcam)
  3. rigger
    rigger
    Thanks for your reply john. At the moment I have the Yellow S-Video running directly into the DVD, therefore I can only watch DVD. So you are saying that I can connect directly into the ARCAM so that I can get TV, Video and DVD. What is the socket called on the amp
