help needed - choice of 2 subwoofers
Discussion in 'Subwoofers' started by pmarb, Dec 2, 2001.
  1. pmarb
    pmarb
    Oct 29, 2001
    890
    28
    Bristol
    +38
    wanting to decide between a Yamaha SW-320 or a REL Q50
    any thoughts people? :)
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,906
    No contest - REL wins every time.
    Don't be put off by the REL Q50 having only a 50 watt amplifier as I am still using the original Q Bass which only had a 40 watt amp but 40 REL watts seem to be the equivalent of many more from other manufacturers.
    Ian
  3. pmarb
    pmarb
    Oct 29, 2001
    890
    28
    Bristol
    +38
    thanks for the post Ian, anyone else? :)
  4. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,494
    United Kingdom
    +2,030
    Go for the Rel.
    I went from a Yamaha 160 to a Rel Q200 - no contest, the Rel is way ahead.
    cheers
  5. dts_boy
    dts_boy
    Nov 26, 2001
    2,621
    Manchester suburbs...
    +178
    bit different but i went from a £180 yamaha sw80 to a M&K vx100...what a difference!!! it is simply worth spending as much as you can on the sub and get cheaper speakers or if your savin just for a sub save a bit longer. my advice would be to listen to a few £700+ subs, you'll understand what i mean!:D
  6. leon
    leon
    May 15, 2001
    1,158
    kent
    +67
    REL is the bizz
    i have a rel storm and it is crisp and sharp ,its 3 years old now and still works a treat also in the past ive have yam subs like the yst60 and 120 but the rel is great
  7. Phil Hinton
    Phil Hinton
    Editor Staff Member
    Jan 18, 2001
    10,144
    3
    +8,132
    I think you now have your answer.
    And as a rel owner i am not biased...........Honest:p
  8. philmate
    philmate
    Nov 6, 2000
    217
    Southend-on-sea
    +4
    Or buy a self build an Iplacoustics SW2 for £285 all in or supply and fit off cuts of MDF yourself and have a sub built and finished in your style £300/400 cheaper..your money but hey...am I the only one.Or spend a grand or more (or the Paradigm at Richers £500 ) a big box but lots and lots of low end ooomphhhh I''ve read and tend to agree with .Its your pennies.
    Philmate.
