Help need to source a glass riser stand
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by kingcobbler, Jul 9, 2017.
  1. kingcobbler
    kingcobbler
    Jul 27, 2004
    1,194
    48
    +61
    due to the amount of kit in the av rack I have the tv sitting on a glass riser shelf. Just got a new tv and the tv stand is a little larger than the old tv, so I need to source a new riser stand.
    Ideally 70cm wide by between 40cm to 50 cm deep, with a rise of 10cm to 14 cm to fit my sky box underneath.
    I'm struggling to get this exact size, can anyone help?
    Or even a place where I can order the glass and somewhere to source the legs?
  2. rogon
    rogon
    Nov 10, 2007
    12
    Did you ever find one I am looking for something similar
  3. kingcobbler
    kingcobbler
    Jul 27, 2004
    1,194
    48
    +61
    No, sorry, surprised there isn't a website where you can order this sort of thing
  4. mushii
    mushii
    Apr 3, 2003
    2,240
    116
    Stoke On Trent
    +1,200
    Any decent Glaziers will be able to order you a piece of toughened glass - I am guessing around an 8mm should be strong enough. If you need holes you will need to specify dimensions and location of each hole as they need to be made before the glass is toughened. You will also need to specify ground bevelled edges.
    If you are struggling try giving Modern Glass in Stoke On Trent, 01782 215519 a call, they are pretty good at custom orders. Be aware that as this is bespoke it wont be cheap.
    Ask for Rob, he is the MD and is an AV fan, he will understand what it is you need.
    Legs - you may need to scavenge something off another unit.
