HELP, need to record audio from a microphone, into my line-in socket on MP3 player!
Discussion in 'Headphones, Earphones & Portable Music' started by jskjas, May 22, 2005.
  1. jskjas
    jskjas
    Hi, my mp3 player has a line-in socket and I want to capture audio from an external microphone, into this line-in (i don't have a mic-in on this mp3 player).
    Is there anyway of doing this, whether it is using some sort of connector in between, or a transformer. I can't seem to pick up anything. I know the microphone itself works, as my MiniDisc has a mic-in which can record the mic audio - yet I want to capture it on my mp3 player if I can.
    Please, can anyone help!
  2. Cardiff Irons
    Cardiff Irons
    Jan 19, 2005
    243
    19
    Auckland
    I'm no expert, but it might be useful if you can tell us what mp3 player you have.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,131
    Rainham Essex
    +2,393
    What you need is a microphone preamp such as This to boost the level output from the mic to line level.
    Mark.
  4. jskjas
    jskjas
    Hi, cheers for the current replies.
    The MP3 player is an XDRUM XD403-PRO, and has a capacity of 1GB (here's a link to its brief description + pic: http://www.kjglobal.co.uk/acatalog/XDrum_XD403.html).
    I actually checked out this maplin preamp a couple of days back, but it states that it needs to be plugged into a mains. I intend to make some short movies with mine, so would ideally would want something that is mobile, which the actor could walk around with - i.e. if it was wireless or phantom powered.
    Is there a wireless or phantom powered alternative to this preamp?
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,131
    Rainham Essex
    +2,393
    Your wish is my command :D
    http://www.keene.co.uk/cgi-bin/bigcodesearch.pl?MB7
    MB7 microphone pre-amplifer
    This allows a mono microphone to be connected to an amplifier (or tape deck etc) with a phono line input. The input is a 6.3mm jack socket and the output is fed equally to the 2 phono line outputs making easy connection to setero equipment. It has a high 40dB gain and very low noise. It’s powered by a 9v PP3 battery, which is switched off automatically when you unplug the mic.
    [MB7] £49.99 (£42.55 ex VAT)
    http://www.keene.co.uk/cgi-bin/bigcodesearch.pl?MB8
    MB8 microphone pre-amplifier
    This is allows a stereo microphone to be connected to an amplifier (or tape deck etc) with a stereo phono line input. The mic input is a 6.3mm jack socket (an adaptor could be used for 3.5mm mic jacks) and the gain is 40db. The power supply is a 9v PP3 battery, which is switched off automatically when you unplug the mic.
    [MB8] £69.99 (£59.57 ex VAT)
    But obviously they do cost a fair bit more :thumbsdow
    Ho Hum,
    Well at least they should do what you want.
    Mark.
  6. jskjas
    jskjas
    cheers MarkE19, i guess these would be the only alternatives around - they are bit pricey...so I might have to stick with my MiniDisc, but if there is even a cheaper alternative still, i would really appreciate anymore suggestions you or anyone else has,
    please, if there is anything cheaper, and even smaller still, that would be great, but cheers in the mean time
