Help need RGB scart to YUV component
Discussion in 'Projectors, Screens & Video Processors' started by minimivic, Aug 3, 2001.
  1. minimivic
    minimivic
    Mar 28, 2001
    230
    Shaftesbury, Dorset
    +16
    Hi all,
    I'm trying to get YUV component video out of an RGB scart, is there a way of stripping the sync from Video output then inserting it onto Green.
    I know it can be done on VGA from Scart.
    Any help would be appreciated.
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
    Sharky: Not sure what you mean here but if you want to convert an RGB signal to YUV then Key Digital in the US do such a device I believe. You might also want to contact Dr John Sim at<br /><a href="http://www.rgbtosvideo.com" target="_blank">www.rgbtosvideo.com</a> or .co.uk not sure which.
    He may do such a device already or may even be working on one....
    Gordon
  3. simoncope
    simoncope
    I think you've got the wrong end of the stick here... a SCART connection supplying RGB cannot give YUV. YUV is one signal carrying luminance, and two signals carrying the colour difference.
    Stripping the sync from the composite video pin on the SCART and then recombining with RGB will give you a variation of RGB (eg RGBs or RGsB etc.), not component YUV. As Gordon says, you will need a convertor of some description.
  4. minimivic
    minimivic
    Mar 28, 2001
    230
    Shaftesbury, Dorset
    +16
    I understand what you are both saying.
    Its an idea I have come up with, and I was wondering if it has been done or if it was possible to convert the RGB signal from the scart to YUV.
    It appears to be hard, but someone must know if its possible or what box of tricks we will need.
    OK.... Can VGA be converted to YUV? I'l try it another way if needed.. <br /> <img src="smile.gif" border="0">
  5. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
    Sharky: RGB can be converted to YUV. YUV is a form of analogue compression of RGB. As I said, Key Digital do such a box of tricks. Dr John Sim of RGBTOSVIDEO.COM may be working on a similar box. I'd expect Extron and Kramer do something similar for much more money.
    VGA is a term bandied about for many things it is not. VGA is a PC resolution. 600 X 480 is VGA unless I'm mistaken. VGA sockets are really High Density 15 pin sockets or HD15's. HD15 sockets can be used to transmit many types of resolutions and signals.
    If your question is "are there any devices which can convert a VGA (600 x 480 PROGRESSIVE)signal to YUV progressive then I'm not sure. I'd guess that Folsom and Snell and Wilcox may be places to look. Alternatively try Key Digital again. I think Oasis may be your best bet for answers to this technical query.
    What is it you are trying to achieve anyway?
    Gordon
  6. minimivic
    minimivic
    Mar 28, 2001
    230
    Shaftesbury, Dorset
    +16
    Gordon
  7. Mr.D
    Mr.D
    Jul 14, 2000
    11,197
    +1,241
    I'm sure lektropacks do an RGB to component transcoder seems to recall 300quid mark.
    I seem to recall that ACE video mixer thing advertised in HCC and What TV also performs rgb to yuv conversion but I'm not 100%.
  8. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
    MrD: Just checked the Lektropak catalogue. They do a device which converts s-video or composite to RGB OR YUV but not one that does RGB TO YUV.
    At least I can't see it....
    Gordon
  9. Mr.D
    Mr.D
    Jul 14, 2000
    11,197
    +1,241
  10. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
  11. museumsteve
    museumsteve
    Jan 28, 2001
    8,003
    4
    Nth Hampshire
    +1,109
    I'm after component to RGB (HD15)..any ideas..can't find one anywhere..I want to use the component out on my DVD to my projector..
  12. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
    If your projector accepts Component in on the HD15 socket then just get a hd15 to 5 phono/bnc lead. Use the R for Pr, G for Y, B for Pb...don#t worry about the hand v cable left over. The sync is carried on Y/G.
    Hope this helps.
    Gordon
  13. museumsteve
    museumsteve
    Jan 28, 2001
    8,003
    4
    Nth Hampshire
    +1,109
    thanks Gordon...The manual says the HD15 takes component (it's selectable through the menu(..any recommendations on where to get them..and if they come with BNC..is there an RCA to BNC adaptor...?? I have BNC to RCA (which I used for plasma)..
  14. minimivic
    minimivic
    Mar 28, 2001
    230
    Shaftesbury, Dorset
    +16
    Museumsteve,
    Lots of Shops can get special cables made up.Try your local one.
    If you get stuck let me know.
  15. museumsteve
    museumsteve
    Jan 28, 2001
    8,003
    4
    Nth Hampshire
    +1,109
    just a note to thank Paul..got my cable today..Component to HD15...I'll be playing later..
