Help need recommendations
Discussion in 'Plasma TVs Forum' started by Dalorp, Oct 8, 2003.
  1. Dalorp
    Dalorp
    Hi all.
    I've read most of this forum and am suitable confused. I have already purchased home cinema kit, dvd player etc and am now looking to buy a plasma.
    I wish to suspend the plasma on a wall and therefore would prefer as few wires as possible actually going up into the display. I aslo don't need any speakers or TV tuner.
    I wish to connect a Sky+ box and DVD (component video) to the display and maybe X-Box
    Any recommendations that I can go away and investigate.
    D
  2. codlord
    codlord
    May 17, 2002
    283
    Portsmouth, UK
    Why have any (visible) wires going to the Plasma at all - either channel and hide them in the wall or hide them in some tubing or make a feature of it and have some stainless/aluminum tubing going to it to feed the wires (see the "Get your plasmas out for the lads" thread for many examples of this sort of thing - can look very nice).
    This way you do not have to worry about the number of cables going to the plasma - and where plasmas are involved having many wires going to it can sometimes be the best/easiest/cheapest option.
  3. Tim_UK
    Tim_UK
    Aug 13, 2003
    34
    I recently bought a philips plasma and this was supplied with matching conduit to hide the connecting cables - I wouldn't be surprised if other manufacturers also include similar.
  4. Dalorp
    Dalorp
    ok what about picture quality for sat tv? I've heard its not brilliant. Does it improve on a smaller screen size? Say 37" rather than 42". I'll be sitting about 9 feet away
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Well with sky+ you can run S-video RGB or YUV through a converter! As for screen then least cables will be a model with a tuner and umbillical cord but these can be difficult and limit connections!
    Phillips and panny do tuner module options PW6 panny have you get a choice.
