HELP : Need Pioneer slot DVD drive for LMP case!
Discussion in 'Desktop & Laptop Computers Forum' started by uk_robk, Feb 28, 2003.
  1. uk_robk
    uk_robk
    I'm very keen on buying a LMP case to build a new HCPC, but the stumbling block is the DVD drive - the Pioneer slot loader models are a bit like gold dust at the moment.
    Can anybody recommend a UK supplier for these drives? Tried scan and microdirect with no success!
    Cheers,
    RobK
  2. Sgt.Colon
    Sgt.Colon
    You could try Dabs.
    www.dabs.com
    or
    www.overclockers.co.uk
    Had a look on Scans site today and it says they have some in stock. You might with to give the a ring to confirm. :smashin:
    Good luck.
  3. uk_robk
    uk_robk
    Thanks for the response, I checked scan page and the SCSI one is available (LN2460) - but I don't know if this one is easy to make multi-region. Will phone them and check stock and get a model number so I can get some more details.
    Is the SCSI one the one you meant is in stock? Or have I missed it?
  4. Sgt.Colon
    Sgt.Colon
    Rob
    No, I meant the IDE one. It's just above the SCSI one. Says CALL where the price should be. :smashin:
    I have this unit and it was very easy to make region free. :clap:
  5. uk_robk
    uk_robk
    Ah yes, that's the one I wanted - but I called them this morning and they are out of stock - none expected until March 28th!!!
    Andy (from LMP cases) has warned me that this drive is getting scarce, he wasn't kidding either!
    RobK
  6. nathan_silly
    nathan_silly
    I have the Pioneer 106S (slot loading IDE version)
    Upgraded to multiregion, no probs.
