Help! need muppets guide to setting up HTPC with panny 42xp70!
Discussion in 'Home Entertainment Computers' started by J_C_COOL, Apr 27, 2007.
  1. J_C_COOL
    J_C_COOL
    Apr 29, 2005
    149
    +3
    Pretty much as it says really, got my tv today and need to what settings to put my pc at. Its connected via hdmi but the desktop is too big no matter what resolution I set it too. Have nvidia 6150 onboard.
    Any ideas?
  2. limblee
    limblee
    Dec 21, 2006
    2,155
    67
    Ruislip
    +235
    what Hz's are you outputting?
  3. J_C_COOL
    J_C_COOL
    Apr 29, 2005
    149
    +3
    60hz afaik. Why?
  4. xxxx
    xxxx
    Aug 27, 2005
    776
    28
    +23
    1216*688 works fine for me.
  5. J_C_COOL
    J_C_COOL
    Apr 29, 2005
    149
    +3
    Yeah tried that but it doesn't seem to like it much. Sets itself on 1176*668 ( iirc) but it leaves black bars all round the edge.
  6. J_C_COOL
    J_C_COOL
    Apr 29, 2005
    149
    +3
    Right I know whats going on but how do I fix it??
    when I put it into 1176*668 the tv treats it as a 720 input but when I try and up it to 1216*688 the tv decides its a 1080 input and reconfigures acordingly.
    Is there a way I can force the tv to stay @ 720?
  7. andyr300
    andyr300
    Apr 9, 2006
    2,134
    +104
    powerstrip may be the way forward
  8. xxxx
    xxxx
    Aug 27, 2005
    776
    28
    +23
    That must be some sort of "improvement" with the new 70 model. I have a PX60 and it does not reconfigure itself.
  9. J_C_COOL
    J_C_COOL
    Apr 29, 2005
    149
    +3
    ok ta will give it a look tonite.
  10. xxxx
    xxxx
    Aug 27, 2005
    776
    28
    +23
    I doubt that Powerstrip will help if your TV is auto-adjusting to the input resolution. You will have to turn the auto-adjustment off.
  11. andyr300
    andyr300
    Apr 9, 2006
    2,134
    +104
    can do sometimes, some programs like MCE will actively change resolution/refresh rate settings when they open,but powerstrip can prevent this happening
  12. xxxx
    xxxx
    Aug 27, 2005
    776
    28
    +23
    That's true, but it's unlikely to have any effect on the screen if the screen is adjusting itself.
  13. paul_warren
    paul_warren
    Nov 23, 2006
    190
    +15
    If you have a separate sound system, you can connect via VGA as the 42px60 supports 1:1 pixel mapping - so the desktop fits perfectly.
