Help Need Leads
Discussion in 'Home Cinema Speakers' started by Chox1988, Jun 23, 2005.
  1. Chox1988
    Chox1988
    Mar 30, 2005
    16,792
    basingstoke
    +9,157
    I have found a shockingly old pair of speakers in my attic and just wanna test them out. I have an amplifier that just uses stripped wire to connect to speakers wih spring clips (dunno technical name). These speakers are old and have a small connector with two inputs one on top of the other using small pins, one at the top is slightly bigger than that below. Wondering what the name of the type of leads I will require is.
    Cheers. :)
    If it helps they are Solavox PR35 MKII Speakers.
  2. Warpaint
    Warpaint
    Jul 26, 2003
    597
    28
    Edinburgh
    +62
    Its probably a a 2 pin DIN plug you need.
  3. Chox1988
    Chox1988
    Mar 30, 2005
    16,792
    basingstoke
    +9,157
    Yep thats the one, Cheers :thumbsup:
