Help!! Need help on which dvd rewriter to buy & what software to use.
Discussion in 'Desktop & Laptop Computers Forum' started by welshboy, Jan 7, 2005.
  1. welshboy
    welshboy
    Jan 6, 2005
    598
    Swansea
    This is my first post.
    Could anyone give me advice on which dvd rewriter to buy i want it to be a dual layer and makes good quality backups.
    I also need some advice on what software to use to copy straight from a dvd i already have to back it up and what software i will need to edit out ads that i have recorded.
    Thanks.
    Hoping someone replys.
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Hi :hiya:
    A recent thread about which DVD writer seemed to settle on the NEC 3520, try searching on that to find the comments.
    To rip DVDs the most widely used program is DVDShrink, it's free and can rip only the movie or whatever you select.
    Not sure what you mean by "edit out the ads that I have recorded".
  3. petrolhead
    petrolhead
    Mar 29, 2002
    4,497
    71
    Newcastle
    +83
    I think he means the trailers at the start of some DVDs
  4. welshboy
    welshboy
    Jan 6, 2005
    598
    Swansea
    Yes what software will i need to delete parts of the dvd e.g Ads, trailers & i also want software so that i can make my own menu on the dvd for tv programes i have recorderd.
    Thanks. :lease:
  5. Embarker
    Embarker
    Apr 19, 2004
    1,626
    Garden of England
    +66
    would second the nec - i built a pc with the nec 3500 and with the speed flash it is silent with dvd - dvd-r are not though which is a shame
    and second shrink aswell especially as it manages nero in the same program
  6. DrPepper
    DrPepper
    Oct 2, 2001
    3,150
    Barking Essex
    +239
  7. welshboy
    welshboy
    Jan 6, 2005
    598
    Swansea
    Does anyone now where the best place to get dvd rewriters is.
    Thanks. :thumbsup:
  8. petrolhead
    petrolhead
    Mar 29, 2002
    4,497
    71
    Newcastle
    +83
    Overclockers for one
  9. watersa@ntlworl
    watersa@ntlworl
  10. welshboy
    welshboy
    Jan 6, 2005
    598
    Swansea
    Hello agan thanks for all of the replys you have all been very helpful and could you tell me which discs i should get to use with the nec 3520 and i want them to be -r.
    Thanks.
  11. Dr Nick Riviera
    Dr Nick Riviera
    Now that I've figured out what media to use, my Sony DRU710 is pretty good. 16x +R, 12x -R, 4x +RW, 4x -RW and 2.4x DL as well as 48x CD, and it's only around £50.
    Software wise I use Nero 6.6.0.3 for burns and DVD Shrink for backups. DVD Decrypter is the way to go IMHO for the DL burns though - Nero is known to have some issues with regard to the layer break (it doesn't put it where the original source break was, and some players are reported to have issues playing onward from the break). Nero Recode is apparently a good alternative to DVD Shrink too - I got it with my drive and am just playing around with it the moment.
    HTH
  12. welshboy
    welshboy
    Jan 6, 2005
    598
    Swansea
    Thanks for that Dr nick that dvd writer will go on my list but where did you buy it from.
    Thanks.
  13. Dr Nick Riviera
    Dr Nick Riviera
    komplett.co.uk and ebuyer both have it for under £60 mate. So far I am very happy with it, but as I said it is a litle fussy about media.
    Nick
