Help! Need budget 32-40" Smart TV that has Airplay2
JBGoode441
Hello,
I am looking to get a budget TV between 32-40 inches that can stream content from my iPhone or iPad via Airplay 2.
Nothing fancy. Info seems scarce.
I know I could get the Samsung Q50R but that is a little over my budget.
Any suggestions are welcomed.
Thanks!
vickster
What is your budget? What country are you in as models vary. Q50 R is an old model so you’d need to go used
If you can’t find a Tv with it, would an Apple TV dongle do the same? Those are cheap second hand if not fussed about 4k or a Firestick? Or Chromecast? Roku?
JBGoode441
thanks for your reply.
I am in Canada.
Needs to be easy to use. I thought about getting cheap TV and hooking up to Apple TV but then again it would probably be easier to pay a little more and get something that is all in one.
thanks.
Dodgexander
Your options open up greatly if you can go for 43". I think all the latest Samsung, LGs and Sony's all have airplay 2.
Rtings.com would be a good place to start your search. Determine which type of panel you want from a TV first.
Most people would opt for a Samsung model such as the TU7000 or TU8000.
