Hi folks,
I'm a little stuck with a decision. I have a pair of Q Acoustics Concept 20s that I want to use with an Audio Technica LP3 and sometime in the future might use Bluetooth.
I'm looking for a sub £200 amp to drive these speakers. I've came across the Cambridge Audio AXA25 which is £180 on Richer Sounds The only problem is that it only has 25W X 2 which is at the lowest end of the power that is needed to drive the Q Acoustics.
Keen to get everyone's input. Are there any good amps out there (ideally with bluetooth) with more power for £200 or less.
Edit: Also found the Sony STR-DH190 but it's rated at 100W x 2 which is a little overpowered
