HELP! - n00b Home Cinema/ Audio Setup
Discussion in 'Home Cinema Speakers' started by emers0n, Oct 27, 2005.
  1. emers0n
    emers0n
    Hi guys,
    I've just signed up, i'm looking for some advice, i'm sure you can help!
    I'm totally new to the AV scene, I'm looking to get a setup for a about £600ish give or take £100...I would like to be be suitable for both Listening to Music and Playing Movies...
    I've been told that a good budget all round amp is the Cambridge Audio 540R...so i've set my sights on that already...
    Looking to get maybe just a 3 speaker setup at the mo...money permitting...consisting of Front speakers and a centre speaker...
    The question being, Which speakers would be good all rounders for both Music and Movies...in a reasonably small room.
    I'm interested in the Kef Q Compact and Q6C Centre...what do you think?
    Any other suggestions?
    Thanks in advance.
  2. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,033
    Harrow, NW London
    +600
    well, tbh if you are happy to do what i did and build the system up over a bit of time, i would consider this route, get the Denon 1906 receiver amp, and a pair of Monitor Audio RS1's.......now thats going to pretty much eat up the £600, if you go to Sevenoaks for this and tell them you will eventually expand to a full system then hopefully you can get them to chuck in some speaker cable cheap or even free ;-)
    the MA RS1's are lovely speakers, i have heard them now, altho i personally own the S series which is the predecessor......
    anyhow, this way, you get a lovely pair of speakers for music and a none too shabby amp, Denon and MA work well together (altho ask in the shop for other options, if you book a demo they will be happy to setup other brands they stock). This then leaves you future options, you can get the RS centre at a later date with a pair of RSFX bi/dipolar (switchable) surrounds, the centre is around £250 and the RSFX's are around £400, but again if you buy them together or during sale season you can get them cheaper, i did when i bought my S series ones..lol......then at some point get a nice sub too, or buy the sub first, then get the surround/centre speakers......then finally a DVD player.....et voila, you will have a spankingly good sounding system, with both music and movies :)
    btw, sorry, i havnt heard the Q series you mentioned, so i wont comment on how they are compared to what i've mentioned.....and i've just realised, did that £600 have to take in to account a DVD player too?....if it did then for the time being find a cheap but decent Toshiba for around £60 to make do untill you can afford one to match the amp.........it seriously is worth taking a year or two buying better components, you end up with something much more lovable than buying as much as you can to begin with for a smaller sum......
