Help, my subwoofer is wierd!
Discussion in 'AV Receivers & Amplifiers' started by Willy, Jan 4, 2003.
  1. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    Hi, I just got myself an av receiver to set up my surround sound system. However, my amp is left over from an old all-in-one speaker package and it has 2 wires (red & black, like normal surround ones) coming out of the back. Unfortunately my amp has a single hole (which I think is standard). So, is there any way to connect them together? I was hoping I could just add a kind of connector to the wire so that it'll be able to slot into the amp. I really hope I dont need a new amp aswell :(
    Thanks.
  2. sounddog
    sounddog
    Dec 11, 2002
    3,437
    107
    Leicestershire, UK
    +477
    Sorry if I'm reading this wrong ... but surely your new AV Reciever has all the amplification you need for the 5/6/7 "main" speakers that you need for Home Cinema.
    An (active) sub then attaches via the "pre-out" for the sub channel.
  3. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    Thanks for the response.
    Err, I'm not sure about this. I just want to try to get the existing speaker set working with my new amp. The surround speakers all connected fine and work ok, but the subwoofer I have just has normal speaker wire and there doesn't seem to be a suitable connection in the amp. I'm really confused about how to try to connect it!
  4. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    Sounds like you have a Passive Subwoofer where the amplification would have been handled by your old All-In-One's Amp. If your Sub is not powered in any way, i.e., does it plug in to the mains, then I think you're beat on this one.
  5. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    I think you're right. Damn, this is getting expensive! Thanks everyone for the help.
  6. mandlebrot
    mandlebrot
    Aug 21, 2001
    426
    16
    Manchester, UK
    Well he could wire it high level to one of the main speakers then set that to large couldn't he? This would not be a great solution but it should work. I would still recommend getting an active sub though.
    Edited to say: Actually not sure this would be a good idea unless the sub has outs for the speakers, if it has not then forget it because the sub would be receiving a full range signal and might not have a filter in it to screen out the high range stuff.
  7. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    Hehe. Thanks, but I didn't understand much of that! :blush:
    I think I'll take your advice and just invest in an active sub.
  8. magking
    magking
    Jan 6, 2001
    380
    Norway
    You should definently go active. Your amp will not like to drive the sub aswell as your fronts.
    Take a look here for good prices on Velodyne subs.
  9. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    OK, cheers.
