Help... my PJ keeps shutting down
Discussion in 'Projectors, Screens & Video Processors' started by SanPedro, Apr 22, 2005.
  1. SanPedro
    SanPedro
    Jan 11, 2001
    4,505
    +505
    Panny A100 with 4500 hours on it.
    Powers up ok. The 'change lamp' message comes on.
    Works for about 10 minutes then goes into shutdown mode.
    Is it overheating or what? Is it worth opening the back up to see if there is a ton of dust n there?
    Chris
  2. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,475
    Surrey. UK.
    +2,118
    Maybe you have to change the lamp?
    I believe some pjs won't run until a new lamp is installed and the counter reset. Is the AE100 one of them?
    Gary.
  3. mickey
    mickey
    Jan 30, 2003
    5,903
    manchester
    +268
    definately lamp replacement needed. it even says so in the manual
  4. thfccambs
    thfccambs
    Jul 17, 2002
    19,148
    White Hart Lane
    +5,255
    I thought this post was a wind up,it even tells you what the problem is. :suicide:
  5. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    Chris,
    Good going to get 4500 hrs..... new lamp is the thing, right enough. How was it performing (apart from the need for a replacement lamp.....) after all those hours ?
    Sean.
  6. SanPedro
    SanPedro
    Jan 11, 2001
    4,505
    +505
    Thanks for the HELPFUL replies , Gary, Mickey and Theritz. Sarcasm I don't need Hunts.
    Sean, the unit is going fine generally. A bit dimmer I guess, but the lamp was still working ok. I guessed the 'change lamp' message was a suggestion rather than an explicit order. Since the change lamp message came on I've had a least a couple of hundred extra hours out of it.
    It could do with a proper clean of the panels though as it has a mass of dust blobs on it at the moment.
    Do you still have that link to the AE100 cleaning routine that somebody once posted?
    And does anybody have any links to cheap lamp suppliers?
    Thanks lads, new I'd get the help I needed here.
    I was thnking the damn thing was overheating or something.
    Chris
  7. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,475
    Surrey. UK.
    +2,118
    Must be a relief to know it's not the pj going faulty though!
    I wonder if the lamp warning is meant to give you a couple of hundred hours to find a new one before it doesn't allow you to run it anymore?
    Gary.
  8. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    Chris,
    Calibos' guide to dust blob removal is in the FAQ - Direct Link . If you need the AE100 Service manual, then it's a 13mb+ download, Right Click Here and Save Target, otherwise it'll take Acrobat an age to load it.
    If you just want to give it a blast with compressed air, there isn't any need to dismantle further than taking the cover off the projector, clear instructions in the service manual. You'll see the main circuit board, three copper coloured ribbon connectors which lead down to the LCD panels - that's where to point the compressed air, making sure that it's ONLY air that comes out, NOT PROPELLANT - propellant could make a very nice mess in the optics.
    Good Luck,
    Sean.
