Help! - My Pioneer reciever has lost the right channel!!!
Discussion in 'AV Receivers & Amplifiers' started by kenlong69, Apr 2, 2003.
Tags:
  1. kenlong69
    kenlong69
    Oct 24, 2002
    505
    Doha
    +6
    Hey all!
    I have a Pioneer VSX859RDS reciever and for some reason it now only plays the left channel when in stereo mode! Before you ask... no I haven't been playing it too loud :rolleyes: I've only ever had it up to -15 volume! It's too loud higher than that!
    I've tested all the inputs with the same result. I can only asume that the left channel has been blown.
    However in Dolby digital, DTS and THX it's fine so it must only be the stereo channel that's gone.
    I have an insurance policy on it that hasn't run out but it means not having an amp fo a few months!!!
    I was wondering if anyone here has had a similat problem and if it may be an easy fix like a fuse of something? I don't really want to loose my amp for that long :(
    Any help would be welcome!
    Cheers,
    ken
  2. Jase
    Jase
    Mar 16, 2001
    9,472
    South Coast
    +895
    Hi Ken
    Can your amp be reset to its factory defaults at all?
    If the right channel had blown, it would be on every mode, not just stereo.
    Sometimes the processors throw a wobbler and need resetting, make sure you write down all your speaker distances, channel delays etc beforehand.
    Another thing to check, you haven´t (or someone else!) lowered the right channel in stereo mode by accident have you?
  3. kenlong69
    kenlong69
    Oct 24, 2002
    505
    Doha
    +6
    Hey Jase! Cheers for the reply! How is Spain? I was chatting to Uncle Eric today (I got a Velodyne off him!) and told him that I'de bought your speakers!
    As for the left channel being turned down... I looked long and hard and it seems you can't change the balance... well unless I'm missing something VERY obvious of course!
    I will take your advice and reset to factory defaults if I can find out how!
    Ken
  4. Jase
    Jase
    Mar 16, 2001
    9,472
    South Coast
    +895
    Spain is fine, as usual! Depends on the amp but I´m not sure whether yours has the ability to individually set the channel levels for each mode. A reset is usually done by holding down a couple of buttons and turning the power on, might vary from amp to amp though.
    Hope you´re pleased with the Velodyne!
  5. kenlong69
    kenlong69
    Oct 24, 2002
    505
    Doha
    +6
    Yeah I don't think there is a balance or setting for each channel (certainly not for each mode!). I'll have a look in the manual to find out how to reset it.
    OR I could save and get a Denon A1SR! ;)
    Ken
    Oh - and the Velodyne is BRILLIANT!
  6. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
    I hade something similar happen a few years back.There was no output from one channel when listening in stereo ( contradiction in terms there :) ) however when multi channel was selected the dead channel now burst into life :confused: .Iirc it was a blown ic. :(
  7. martian1
    martian1
    Dec 30, 2001
    2,239
    83
    Sunderland
    +271
    Ive had this but it was my fault! Hope this helps, i was messing moving my gear or setting up my stereo amp and i noticed when playing in pro logic 2 or c.surround i lost one of my front channels [ a have a marantz amp] i thought thats it its knackered.
    But after many frustrated hours [ having remembered about the messing around with gear] i had a look at all the connections and found that my right lead into Sky box had fell out....check and see.
  8. kenlong69
    kenlong69
    Oct 24, 2002
    505
    Doha
    +6
    martian - cheers for the tip. I thought of that but it's happening with all my inputs. CD, DVD, tape etc etc... it seems the right side is just gone!
    But it's fine in Dolby Digital and THX modes... are the stereo and DD amplifiers seperate???
    Ken
  9. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    No, definately the same amplifiers. There will almost certainly be some circuitry within the amp that is different for the stereo output though, so like lynx said:
  10. kenlong69
    kenlong69
    Oct 24, 2002
    505
    Doha
    +6
    IC? Is it something I can replace myself? I'm fairly handy ;)
    I just hate the thhought of having to send my amp away for months!
    Ken
  11. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    Integrated Circuit. It's impossible to say whether you could replace it yourself but it's very unlikely you'd even be able to buy the part.
    I'd be more concerned with the 'Insurance' you've got. Why would you be without it for a few months?????
  12. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    Just a thought of what might be the rproblem ... not that it helps ... but if you are having problems with all the analogue inputs ... maybe (half) the Analogue Digital Converter has blown.
    As has already been said it doesn't help cause you can't replace it yourself or anything ... but just a thought!!
    Does you amp have a true analogue bypass, possibly try connecting a CD player or similar to the 5.1 multi-channel input if you have one.
    Vikki
  13. hamtaro
    hamtaro
    thx?
  14. kenlong69
    kenlong69
    Oct 24, 2002
    505
    Doha
    +6
    Noodle - Yeah I'm going to call my insurance to see what they offer.
    Vikki - Do the analogue inputs (i.e. - the phono-type CD, VCR 1 etc etc) get converted back to digital before they are output to the speakers???
    hamtaro - thx what? :)
    Ken
