help my camera is bust?fuji 6800 zoom
Discussion in 'Photography Forums' started by motty, Jun 2, 2003.
  1. motty
    motty
    Aug 11, 2002
    i have just turned on my fuji 6800zoom and the lens wont move out.When i turn on the display it goes peep peep peep a couple of times and says !lens cover on the lcd screen at the back.
    What should i do
  2. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Lytham St Annes, where people are put out to grass
  3. warpedmind
    warpedmind
    Ihad a mate with same probs and he say to remove memory card and clean hinges on flap as there are contact point that need to connect could be just a bit of dirt.
