Help my Bravia won't prog scan
Discussion in 'LCD & LED LCD TVs Forum' started by petedameat, Feb 10, 2009.
Tags:
  1. petedameat
    petedameat
    Feb 10, 2009
    3
    Hi all,
    I have a Sony Bravia KDL 40L4000 which I use with a SONYDAVDZ260 home cinema system via HDMI. When I try to view 1080p I get pixel dots all over the screen. This does not occur using 1080i. I have tried all settings that I can see.
    Cant anybody help please.
  2. alsina
    alsina
    Nov 30, 2008
    3,796
    +605
    Where is the HDMI cable from? Might be worth trying another one as this can be a sympton of a cheaply made cable.
  3. petedameat
    petedameat
    Feb 10, 2009
    3
    Thanks Alsina,
    Yes it is a cheap HDMI cable, I had a Monster cable ordered from Play.com but it never turned up so I bought a cheap one from Tesco's. I will get a hold of a better quality one and give it a go. Thanks for your reply.
  4. Torper
    Torper
    Apr 9, 2008
    102
    +10
    Is there really any difference between a cheap HDMI cable and an expensive one? My understanding is that digital signals aren't affected by cheaper cables - a digital signal, unlike an analogue one, is either on or off.
  5. YellowSphere
    YellowSphere
    Dec 2, 2007
    4,448
    103
    +471
    First of all a "good" cable isn't necessarily expensive. Monster, for example, is not worth the money. There are plenty of decent, not expensive, HDMI cables available from websites like amazon, ukhdmi, hdcable.co.uk, or perhaps Mark Grant.
    As the bit error rate increases over distance, or with higher bandwidth signals, on poorer cables, the likelyhood of image problems increases. These aren't necessarily completely losing the picture, but problems with dots all over the image, or sudden blocking, or dropouts or anything else. You wouldn't have things that magazines like What Hi-Fi elude to where a different cable might lead to a slight increase in sharpness or something.
  6. petedameat
    petedameat
    Feb 10, 2009
    3
    Thanks everyone for your advive/comments.
    I tried Pure AV HDMI cable from a friend and that solved the problem. I am sure the cable debate will carry on but for now I intend to spend a few extra quid on a new HDMI cable.
