Help - Mpeg Playback Audio Sync Problems
MikeTV
Foolishly, I installed a codec bundle from the internet, and now when I play my mpg files, the audio is out of sync with the video (the audio appears to be faster than the video). I know my mpg's play fine usually.
I am using Power DVD XP for playback. I have tried uninstalling the various parts of the codec bundle, but it doesn't help. Does anybody know which codec is likely to be causing this? I guess I can reinstall power dvd again, and that might fix it. I appear to have a lot of codecs installed now, but I don' even know whether it's the video or the audio codec that's misbehaving. It's codec hell!
I've had this before after installing some codecs. I don't remember how I fixed it previously - probably uninstalled/reinstalled something.
Tim Cooper
Are you running XP? if so try a system restore a point before you installed the codecs.
Tim.
⭐ Philips OLED+908 TV preview + Avid Accent amplifier reviews + Hi-Fi & AV News
Back
