Help Me
Discussion in 'Photography Forums' started by Alligator69, Nov 28, 2004.
  1. Alligator69
    Alligator69
    hi my name is dan
    i have a problem, my digital camera which is a olympusc-220-zoom(whateva that means) and i tried to drag pictures off of the memory thing and now whenever i try to take a picture the lens doesnt come out and a blue screen shows up on the display part and says
    d:
    3403
    1e13
    1e12
    plus when i went into the removable disk place where all the files were and there was nothing there..... plus im going to dreamworld tomorrow and i need the camera !!!!!
    so could some one please tell me how to fix if i can fix this problem?
  2. Geordie Jester
    Geordie Jester
    Oct 14, 2003
    1,437
    +157
    Sounds like a corrupt smartmedia card. Will the camera not allow you to reformat ? (the hammer type icon). Otherwise you might need to put it into a PC card reader so that you can wipe and fix.
