Help me with Velodyne CHT15
Discussion in 'Subwoofers' started by petrolhead, Apr 27, 2003.
  1. petrolhead
    petrolhead
    Mar 29, 2002
    4,776
    Newcastle
    +114
    Very tempted to buy one of these.
    Currently run a Rel Strata III but have the upgrade bug.
    Looking for lower, tighter bass. (Trouser Flapping :) )
    Room size is 12" x 13"
    Running Kefs
    Some one has suggested it may be too big for the room.
    Of the guys here who won one what is your room size?
  2. paulfd
    paulfd
    May 18, 2002
    52
    Luton
    Hi m8,
    My room is slightly larger than yours but mine's ok (16 x 14). Volume set to 3.5 ish on the sub amp and it just delivers. :)
    The only thing is that whilst a box at 2' x 2' x 2' doesn't sound too big, it does require floor space. A 6 cubic feet box is not small.
  3. rjw
    rjw
    Sep 6, 2002
    204
    Bath
    +5
    My room is almost identical in size to yours, no problems with my CHT-15.
  4. Godfather
    Godfather
    Feb 12, 2001
    2,345
    63
    Edinburgh
    +225
    My CHT-15 sounds great in my room measuring 16x9' (matches my widescreen TV!). I don't think it's too big.
  5. petrolhead
    petrolhead
    Mar 29, 2002
    4,776
    Newcastle
    +114
    Cheers for the support guys.
    Godfather I notice you have a BFD, has it helped. Spoke to Steve.Ex last night and he sung its praises.
  6. Godfather
    Godfather
    Feb 12, 2001
    2,345
    63
    Edinburgh
    +225
    To say it's helped a lot would be an understatement. It's one of the most cost effective upgrade I've ever come across. I'd go so far as saying that an equalized CHT-15 would probably sound better than an unequalized HGS. I'm no expert but the effect of the room on bass frequencies is huge. That's where the BFD comes in. By filtering out unpleasant room-induced peaks, it removes any traces of boom resulting in much 'cleaner' bass. Room treatment would be an alternative but is not really a feasible option in most people's homes.
    So big thanks to Apocalypse for introducing me to the BFD!
  7. codling
    codling
    Jul 5, 2001
    430
    hartlepool
    +15
    got me one coming monday/tuesday.
    i've ran the sinwave test and used the spead sheet on exel(thanks apocolyse,great review/links page),
    ive got a 10db peak at 36hz,10bd drop at 56hz and another 9db peak at a 100hz.
    so cant wait to see what this baby can do,for £100 this sounds a steal.
    carl
  8. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    It's 6ft³ :D
  9. petrolhead
    petrolhead
    Mar 29, 2002
    4,776
    Newcastle
    +114
    216
  10. paulfd
    paulfd
    May 18, 2002
    52
    Luton
    :rotfl: :rotfl: :rotfl:
  11. tk2001
    tk2001
    Nov 4, 2001
    1,378
    48
    +36
    Godfather, are you saying that you don't get boomy bass with your CHT-15 & BFD at ALL?
  12. Godfather
    Godfather
    Feb 12, 2001
    2,345
    63
    Edinburgh
    +225
    That's right. I don't get boomy bass at all after adding the BFD. It almost sounds too good to be true, but it is. :)
    Before getting a BFD, why don't you use a SPL meter to measure your room response? Then you'll be able to see if there're any nasty peaks that need to be tamed. I can send you a CDR of the test tones if you want.
  13. Godfather
    Godfather
    Feb 12, 2001
    2,345
    63
    Edinburgh
    +225
    I just helped my dad set up a REL Q50 in his new flat. Moved the sub around the room but couldn't find a spot where there was no boom. Did some quick measurements with the SPL meter and found a huge peak at 40Hz and a couple of smaller ones at 50Hz and 80Hz. Those were the hot spots causing boom. So I connected up a BFD and here are the results after applying 3 filters:
    [​IMG]
    The difference is instantly audible. No more boom.
  14. petrolhead
    petrolhead
    Mar 29, 2002
    4,776
    Newcastle
    +114
    This seems amazing. I know apoc has a site re seting up but in you opnion is it fairly straight forward
  15. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    I'm also very tempted
  16. Godfather
    Godfather
    Feb 12, 2001
    2,345
    63
    Edinburgh
    +225
    It's fairly straight forward, but does take a few hours before you really get the hang of it. After that it becomes very easy - it took me about half an hour to get the above results with the REL.
  17. petrolhead
    petrolhead
    Mar 29, 2002
    4,776
    Newcastle
    +114
    Well I've ordered the CHT15. Getting delivered on Friday so will take the day off and play
    I hope it's raining :)
  18. tk2001
    tk2001
    Nov 4, 2001
    1,378
    48
    +36
    Hi Godfather,
    The test tones that you mention, do they differ from the test tones (frequency-sweep from 100Hz to 20Hz) found in Avia?
    BTW, do you have a pic of the BDF amounst your AV set-up and does it look obstrusive?
  19. Godfather
    Godfather
    Feb 12, 2001
    2,345
    63
    Edinburgh
    +225
    The test tones I talk about are a set of 21 ten-second sinewaves at frequencies between 16 and 160Hz. I've got them on a 21 track CDR. Basically you play the disc with just the subwoofer connected (or turn off the other speakers on your amp/receiver) and use the SPL to measure the volume of the sub at the above frequencies which are: 16, 18, 20, 22, 25, 28, 32, 36, 40, 45, 50, 56, 63, 71, 80, 89, 100, 111, 125, 143, 160Hz.
    I've tried using AVIA but I find the sweep too fast for taking accurate measurements. As I said, each of the above frequencies plays for 10 seconds so you have plenty of time. I enter the numbers directly into Excel which automatically plots a graph. Have a look on Apocalypse's page for details of where to download the Excel 'program'. The above test tones can also be downloaded.
    I'll take a pic of my setup with my BFD and post it here later.
  20. nathan_silly
    nathan_silly
    Doesn't the BFD got built-in tones? Also does it have a SPL mic input so it'll run a wizard and sort everything out?
  21. Godfather
    Godfather
    Feb 12, 2001
    2,345
    63
    Edinburgh
    +225
    Don't think it has any internal test tones. It does have a mic input and is capable of searching out feedback frequencies and destryoing them, hence the name. :)
    What it won't do is automatically equalize your subwoofer and produce a perfect house curve. You'll have to do that yourself!
    Can't find my camera at the moment but here's a pic of my room with the BFD at the bottom (I know I need a new rack). Will try to take a closeup of the BFD later.
    [​IMG]
  22. Godfather
    Godfather
    Feb 12, 2001
    2,345
    63
    Edinburgh
    +225
    Here's a close-up:
    [​IMG]
  23. nathan_silly
    nathan_silly
    Your system looks weird :)
    I'm used to my poweramps & processor setup.
    Do you have a problem with the Nexus stands? (I find them too light & wobby)
  24. Godfather
    Godfather
    Feb 12, 2001
    2,345
    63
    Edinburgh
    +225
    I find them a bit wobbly too but as my speakers aren't that heavy, I guess they're good enough for now. Next time I'll get something really heavy and sturdy.
  25. tk2001
    tk2001
    Nov 4, 2001
    1,378
    48
    +36
    Godfather, very nice set-up you got there btw.
    I'm trying to attach a graph which contains the frequency response to my CHT-15 but a message comes up with:
    "The image that you have attached is too big. Please make it no bigger than 300 x 300."
    How can it be too big when everyone elses graph is much bigger than mine?
  26. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
    TK upload your image to an image hosting site and then link to it.
  27. petrolhead
    petrolhead
    Mar 29, 2002
    4,776
    Newcastle
    +114
    Very smart Godfather. Do you not find the sound pans stangely with the ctr being so high.
  28. Godfather
    Godfather
    Feb 12, 2001
    2,345
    63
    Edinburgh
    +225
    It's a bit high but it's tilted downwards and I'm sitting about 12 feet away, so I haven't noticed any problems with pans, etc.
  29. tk2001
    tk2001
    Nov 4, 2001
    1,378
    48
    +36
  30. Godfather
    Godfather
    Feb 12, 2001
    2,345
    63
    Edinburgh
    +225
    That doesn't look too bad. Nothing the BFD can't handle. :)
    I'd use 3 or 4 filters to bring the 30-60Hz section down towards the 90dB line and another filter to tackle that 90Hz spike.
    Did you use this Excel program?
    http://www.snapbug.ws/subtestmodel.xls
    If you enter your figures onto the chart, it'll readjust the values to compensate for the inaccuracies of the Radioshack SPL meter (especially for low dBs). So the curve to the left your 40Hz peak won't be quite as steep as on your graph. I've got your details so I'll send you a CDR of the test tones tomorrow morning.
