HELP me with my scarts
Discussion in 'Plasma TVs Forum' started by MrFurious, Sep 10, 2004.
  1. MrFurious
    MrFurious
    Sep 9, 2000
    14,961
    137
    Cardigan Wales
    +1,885
    My ixos scarts do not fit in the back of my viera,they are too long,please could someone suggest some good scarts,i want a scart to s-vhs for the sky+
    and a scart to scart to the dvd player,where can i get good ones but not too expensive?i'm spent after the viera
  2. Orlando
    Orlando
    Feb 2, 2004
    158
    Essex
    +5
    I bought a THOR scart lead and a component cable from 'TV cables'. They are a sponser of this forum. Both including postage and packaging were about £24.
    I also have the Viera and they both fit perfectly.
    You say your exsisting scarts are to long?
    If you still have the plastic cover on the back of the set, take it off, I found it very restrictive if you have alot of equipment connected to the back, and once the teles pushed back to the wall you can't see behind it anyway. :hiya:
