Help me with my HD5!
Discussion in 'Headphones, Earphones & Portable Music' started by wilto, Mar 23, 2006.
  1. wilto
    wilto
    Apr 23, 2005
    309
    Cardiff
    I don't have my HD5 manual on me so could some one be kind enough to help me out?
    I have 2 comptuers and how do i take music from both of these computers without Sonicstage wiping the HD5 everytime?
  2. shadowritten
    shadowritten
    Have SonicStage installed on both PCs and make sure that the content you want to transfer to your HD5 from either of them is NOT copy protected. If you're using 3.2 or later, this should be an easy task. I know it was for me between home and work. Naturally, you can't transfer the stuff off again, but hey ...
  3. RandomLee
    RandomLee
    Feb 17, 2006
    9,175
    Just check my IP address
    +2,948
