Question Help me with diagnosing gpu issue
Discussion in 'Computer Components' started by dollag, Aug 23, 2018.
Tags:
  1. dollag
    dollag
    May 30, 2015
    2,022
    116
    Kent
    +845
    Looking for some advice,
    recently built a new pc
    Mobo: Asrock Z370 mini itx
    CPU: i7 8700k
    16gb DDR4 ram
    corsair sf450
    I have another pc and using a evga gtx 1050 2gb gpu and all is well in that as It's for work and light cad designs
    I took the gpu home to see what difference it made instead of using integrated graphics on the 8700k (only trying out some mmo's no power hungry games;) however, the machine would not recognise the card??
    -checked the bios and primary graphics are for pci.
    -unplugged all sata as m.2 is running windows
    -reset the board and no difference.
    -checked the wattage at the wall and under load im at around 150W
    - the gpu powers up from the pci slot so no external power to the psu
    - cannot download drivers as it will not pick up the card
    - checked dxdiag & device manager and not there
    I put the gpu back in my work pc and all is well.
    I am at a loss and think the pci slot is dead. I do not have another pci card to check which is frustrating. any ideas??
  2. brunation
    brunation
    Jul 26, 2004
    1,212
    63
    Glasgow
    +111
    Fatal1ty Z370 Gaming-ITX/ac ?
    Bios version?
  3. dollag
    dollag
    May 30, 2015
    2,022
    116
    Kent
    +845
    yuyep was the bios version :) all sorted
