Could i connect my equip as follows to a panny 6?? (And are there better ways!?) Sky rgb scart >>> DVD player scart connection DVD player Component out >>> Panny VGA Can i input the sky to the tosh 220 scart socket and make it come out of the component side??? I really havent got a clue?
but as i won't be getting any boards with the business panel i won't have a scart or component board. Can i not wire it as described??? Don't really fancy buying extra boards thats all
no tosh wont convert rgb to yuv buy the panels they are less£100 each and your paying how many £1000's for the screen!
yeah i realise the cost comparison but if i don't need to spend another £200 all the better i say. Plus the other main reason is i only want one cable going to the screen not lots as the it is an old cottage with very thick stone walls and its gonna be hassle hiding one cable let along a couple. anyone else know if this will work?
i think the manual says it will switch so what sort of cable do i use from and to the amp for skybox and dvd? sorry i'm a bit new to using component
you need a converter like the ones JS technology do SKY>scart>conv>3 phono>yam yam>3 phono>screen DVD>3 phono>yam
