Help Me - Which TV?
New Bloke
I have short listed two televisions and I will buying it before the end of the month:
Toshiba 32ZP18P
Panasonic TX-32PL10
I have heard that the Tosh has had some problems but if I go for the Panasonic, I will be buying a separate cinema system.
Unless you have any other ideas?
Is Sony still a good TV to go for, reviews are showing that they are not the best.
Please help.
rct
Consider the Sony LS-60 which I think is in your price range... Squirrel God has one and reports suggest it is rather good for the price. If you can stretch your budget a little, take a look at the Philips Pixel+ range. :)
B
bobbles
After extensive reseach i bought the Tosh 32ZP18P early this year
I was rather peturbed when the ZP18Q arrived
It turned out it replaced the ZP18P
I've never experinced any problems what-so-ever. Maybe most of the probs with the P have been fixed with the Q
My only regret is that i didn't go for the 36 if you can afford the money and the space it is well worth the extra
i can not recommend it highly enough it is a fantastic TV easy to use and has component inputs for the Tosh DVD players
I sold my Sony and bought the 220E Tosh the updated 210 which beats the absolute pants off the Sony, go for a multi region thou if you are in the market
the 32ZP18Q is under 1100 inc P&P from Robertsons online
Lewis used to price match too
the 36ZP18Q is 1390:p
Samsung QN800B 8K TV Review
