elementoulis
Hello everyone! Quite new to the forum , first post actually. I joined as I have been really helped greatly from this forum at times while Google searching. So this is my first post and it's not a question post per se, although it might contain some questions along the way, but rather a validation of what I have, what I set up, and if through reading stuff on the internet (mostly here) I get the best possible experience from my setup in what it is.
Now, before I get deeper just a disclaimer. These components were not bought with the thought of a setup to begin with. So there was no thought going into compatibility, performance etc. There were just components that I happened to need at a given time, separately from each other and I ended up putting them together. In that sense I am not especially willing to buy new stuff, unless the purchase itself is quite negligible i.e. less than 50$ or 50€ (each one suits their own
So my setup is the following -
Samsung UE55KS7000 hooked up:
So my configuration ended up being like that -
My NAS acts as a dumb bucket that just hosts files. My NVIDIA Shield (also a PLEX server) reads those files and my NVIDIA Shield again (additionally a PLEX client communicating with the PLEX server) reproduces those files on my TV via HDMI.
To resolve some of my playback issues one thing I have done is go to my Samsung TV and found an option called "HDMI Audio Input". Out of the two available options (Bitstream, PCM) I chose PCM. I read here in this forum that having Bitstream set at the receiver (that being my TV) actually forces the receiver to decode the sound stream, whereas PCM at the receiver forces the source to decode the sound stream and send it to the receiver. I saw that my TV only supports AAC and nothing new and fancy so it would struggle in Bitstream trying to decode all those DTS(-MA)/TrueHD. So I thought to leave this job for my NVIDIA SHIELD.
On my NVIDIA Shield I made sure to enable all options such as enabling Dolby Audio Processing and other codecs that were listed in advanced sound settings. I also did some research and while NVIDIA doesn't clearly state which codecs are supported by the SHIELD - users on Reddit state that NVIDIA Shield practically is able to handle all consumer-known codecs and it's a complete solution.
Now if up to here I am good, and I'll leave all you confirm whether that's true or not, here comes the tricky part. My Samsung TV also has a second option. "Digital Audio Output" which very weirdly offers the options, PCM (always available and default), Dolby Digital , DTS , DTS Neo 2:5 (those 3 are disabled and only enable on occasion). My questions here are:
Thank you for your time!
- via HDMI to a NVIDIA Shield Pro
- and via SPDIF Optic Cable to a Logitech Z906 5.1 speaker system
- Will any of the other 3 formats become available, based on the premise that I feed the TV a PCM format?
- If yes, should I change to an available format other than PCM for the output or is it better to leave it at PCM for the output as well and leave the Z906 system decide what to do with it?
- Again, if I leave it at PCM for the output will the 5.1 Z906 speakers be able to play correct surround sound (assuming the movie is indeed a 5.1 or 7.1 movie)?
- Alternative scenario: Should I turn my TV back to Bitstream (for input) but stay clear of some specific codecs when I search for movies so that the TV won't struggle? Would that be more worth?
