jonone
Established Member
- Joined
- Feb 17, 2010
- Messages
- 488
- Reaction score
- 99
- Points
- 111
So I have been enjoying my diy td15h+, I'm primarily a music listener and this driver is super clean and and music sounds deep fast and accurate, definitely an upgrade from my bk xxls400.
I kind of stumbled upon this diy setup after being slightly pushed into the driver and cab size etc, and I can't quite help but think I'm missing out a little, the driver does roll off slightly at the bottom end and because of the vented phase plug you get a little chuffing below 25hz by this is only noticeable playing a 20hz test tone, it's not a real world problem per say as you don't hear it in films or music.
But it's like the ultimate bass/mid bass driver in fact it's killer in this sense, but I can't help feeling it's not a true sub in the 30hz and below sense.
So the av15h has been released and I've also talked to nick about about a hst15.
My box size is 17.5" cube so I roughly make it 45l with my 950w plate amp and a driver, or about 50l if I get rid of the plate amp which means I can get have more power in the sense of getting somthing like a inuke3000.
I would like to retain that clean musical which I get from the td15 so the av15 appeals, I wonder if the higher le of the hst is noticable real world?
So would one of you guys help me out and model the above against my td15h+ I would really appreciate it.
