Help me understand "Viewed"
Discussion in 'Satellite TV, Sky TV & FreeSat' started by gers1978, Sep 11, 2007.
  1. gers1978
    gers1978
    Aug 2, 2006
    1,581
    Glasgow
    +173
    As far as I know, if your Sky+ is full, it will overwrite the oldest stuff that you've already viewed, unless you've marked it as keep.
    I've also noticed that a recording changes from Recorded to Viewed as SOON as you view it, even if you only view 1 second and exit out.
    So with regards to what I said in paragraph 1, does it only overwrite stuff that has been COMPLETELY viewed (i.e. all the way through), or does it overwrite ANYTHING that's marked as "Viewed" in the planner?
    Also does anyone know if you can manually toggle a recording between "viewed" and "recorded"?
  2. alternate
    alternate
    viewed is viewed no matter how much you watched.
    No way that I know of switching it back.
    I turn all automatic options off though.
  3. gers1978
    gers1978
    Aug 2, 2006
    1,581
    Glasgow
    +173
    It's a bit silly, seeing as they already have "Part Recorded", why can't they have "Part Viewed"?
  4. Andrew_arkless
    Andrew_arkless
    Sep 19, 2001
    181
    Essex
    +6
    Probably because virtually everything would be marked as part viewed unless you continue to watch any padding/adverts etc at the end of a recorded program.
  5. Techno
    Techno
    Nov 20, 2003
    312
    Anything that's 'viewed' that you want to make sure isn't overwritten can be 'kept' i.e. press the (iirc) blue button to set a Keep next to it.
  6. alternate
    alternate
    I don't think "part viewed" would work. What if you jump to the end to make sure it all recorded and then go back to the start. It would just confuse people.
