Sun
Allo,
Bit of advice if you will,
I have ordered some Wharfedale Diamond 8.1s for use as rear speakers. I need some stands for these that clear 70cm as that is the height of the arms on my sofa. I am guessing that I will therefore need adjustable stands. Although they dont need to be much higher I guess as then there will be 30cm of speaker on top of it.
Wharfedale 8.1s
HxWxD (mm): 296 x 198 x 181
Right firstly how do they attach to the stands? I'm not going to have to nail them on or anything am I? Can the speaker be bigger than the plate it sits on?
Secondly, where is a good place to get some and are there any rules of thumb for good stands? I am definitely not looking for any that are > £60
Mat
Wharfedale 8.1s
Mat
