Help me turn me PC into a HCPC
Discussion in 'Desktop & Laptop Computers Forum' started by dUnKle, Jul 2, 2001.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    15,277
    +2,279
    I have had the capability to output video to my TV from PCs Voodoo 3 3000 for ages but only tried it yesterday and I have to say I was mighty impressed with the video quality.
    However I have a few problems,
    How do I get 5.1 sound from my PC what is a good quality ( yet cheap ) soundcard, I currently have an SB Live card.
  2. GarryF
    GarryF
    Aug 30, 2000
    1,428
    83
    Scotland
    +339
    I remember reading about a cheap "daughter" card for adding to a SBLive, was called Hoontech, on avsforum people talked about them costing $10-$15, no idea where to get one in the uk though.
    Will connect to your SBLive using an internal cable and use up another slot.
  3. Guest
    there are a few cmedia based cards around that offer spdif out, i had one called a busby 4.1
    im not sure if it could only output 4.1 or whether it could output the full 5.1 signal
    however the card cost me £12 and ive seen other varients with the same chipset selling for £9
  4. Desmo
    Desmo
    Jan 4, 2001
    14,196
    Braintree, Essex.
    +5,877
    You've already got what you need :)
    Use the SP/DIF socket on your soundcard (the yellow socket I beleive) to run into the digital coax on a DD amp.
    Thats it, done and dusted. As long as your software player supports DD/DTS this will pass the sound stream straight through to the amp for decoding.
  5. dUnKle
    dUnKle
    Jan 1, 2001
    15,277
    +2,279
    I only have the budget card so it just has 4 out put type things on back none of them yellow.
    Also what is the best ( FREE ) software DVD player and were can I get it from
  6. jason t
    jason t
    Mar 4, 2001
    1,707
    48
    kent
    +38
    hi
    i have just bought a sound blaster pci 16
    on the settings tab in device manager i set it to digital and that turns the green socket into a spidf,and it works !!!
    i have had my amp auto switching using this card from dd 5.1 and dts
    hope this helps
    jason
