Martin Garcia
- Joined
- Jul 20, 2014
- Messages
- 9
- Reaction score
- 1
- Points
- 4
- Age
- 46
Hi all,
I'm finally looking at proposals to create my dreamed (kind of) home theater. My budget is 10 to 12K.
I have look into three different places/companies to do this project and they have provided me with different quotes. I will like to have your help to determine the best option for my money or even if I should combine their offerings.
Please find attached the room dimension diagram plus the file with the proposals.
Some comments about each proposal:
Option-1:
- Not sure about projector compared with the 6030UB
- High Labor cost
Option-2:
- Not sure about the screen.
- Are they using better speakers ?
- EXPENSIVE (If I downsize the speakers to DALI ZENSOR 7 I will save like 1k. What do you think? Is really worthy those 1K extra for the speakers?)
Option-3:
- I'm not sure about the speakers Paradigm. Specially his comment about putting them on the wall flat (not pointing to me).
In addition I was thinking I can save some money by not getting the universal remote control. I don't really think I need that. Any comments ?
Thanks and regards,
Option-1:
- High Labor cost
Option-2:
Option-3:
Thanks and regards,
